problems with cat2 louverd high frequency fittings | on ElectriciansForums
Discuss problems with cat2 louverd high frequency fittings in the Australia area at ElectriciansForums.net
northern ireland
hi folks got a call from a customer saying that she needed 6 4ft flourescents tubes so wen i called to change them 2 out of the 4 in the fitting were flickering, changed them anyway needless to say it didnt cure it, which leads to me to believe the electronic ballast is faulty. Has anyone had problems with the balllast on high frequency fittings? apparently they've only been fitted year or so galaxy i think is the make.
Reply to problems with cat2 louverd high frequency fittings in the Australia area at ElectriciansForums.net
