Product info pack. | on ElectriciansForums
Discuss Product info pack. in the UK Electrical Forum area at ElectriciansForums.net
TJC1
United Kingdom
Has anyone supplied a product infomation pack for a job. Doing a job in a hospital and they want an product info pack. Info on products, test forms etc.
Has anyone got an example?
You just need to produce an "as fitted" manual
A ring file with plastic wallets is the way I have done it in the past and insert those pieces of paper that you find with fittings and accessories when you open boxes, any maintenance required for the fitted equipment along with test schedules, as fitted drawings these may be on paper, CD, DVD,memory card or USB drive depending the requirements of the specification, warranty / guarantee documents for the fitted equipment, copy of the original spec for the work carried out and of course all the test certs.
Basically everything that makes up the installation is documented similar to how you would for ISO 9000
Reply to Product info pack. in the UK Electrical Forum area at ElectriciansForums.net
The previous ones I have used were UK
This is an RSS feed of thread: Saying hello to all on plumbers forum Content of the thread: Job opportunity Hi Everyone, Not used this platform...
