K
Knobhead
This must have happened to some of you.
You’re asked to design a control system for a machine, you think you’ve taken every thing in to account. Finished you hand it over to production.
You’ve taken every thing in to account?
I’ll start the ball rolling:
The foundry I worked at had an extensive rail system, all points on the main run were electro/hydraulic operated by the loco driver via a “slap” push button mounted on a post at the side of the track. All the driver had to do was hit the button as he drove past if he wanted to change the points direction. Signal lights were at the side of the points and repeated on a post showed the direction.
Over time the original control panels began to fail so I was asked to build new panels for them.
Now this may seem a weird way to go about it but I used a PLC program for the original design and then transferred it to relay logic. It meant I could make changes quickly.
Back to the story, all panels in and working for about 6 months without trouble. I arrived at work one afternoon to find the place in chaos. The one set of points that there was no alternative rout around had a 60Ton iron transfer car and loco derailed across them.
So what had gone wrong? The driver of the loco had hit the “slap” button that hard he bent and jammed it so the points are turning Left, Right, Left, Right. During change over the signal lights turn off to indicate no clear road. No clear road, did that stop our intrepid loco driver, like hell it did! So he arrives at the points pushing the transfer car. First axle goes left, second right, loco left!
It only took a one shot timer to sort the problem.
I hadn’t taken in to account just how brutal, heavy handed and stupid our operators could be!
