Professional Cable Locator Kit | on ElectriciansForums
Guest viewing is limited
Discuss Professional Cable Locator Kit in the Electrical Tools and Products area at ElectriciansForums.net
yep, dont use it very often now, but used it a lot a couple of years ago. great kit.
Did you have this exact same one or just one like it?
What did you use it for mainly? Tracing cables or as a circuit finder? it does do both right... Just trying to find out it's benefits
What do you want it for?
I use a telecom tone type, like a fuse finder but on a dead circuit. It injects 2 tones down any 2 dead cables, its brilliant for tracing circuits.
Well... I'd like to use it to trace cables in Walls (similar to what the cr*py Bosch ones are supposed to do) and hopefully this will be alot more accurate and reliable
and also as a MCB/fuse finder...
From what it says this will do both in one unit... Oh and also trace cables unto 2.5m underground which sounds pretty snazzy
If you get one, give it a write up. I considered buying one but didn't know if it would bring anything else to the party. I have a Martindale fuse finder FD650 Martindale FD650 Elite Fuse Finder Kit for live circuits and the telecom tone for dead. Both together seem to cover all the bases.
Use the tone mostly as you can skim over sockets and walls and it reads the tone effortlessly
Reply to Professional Cable Locator Kit in the Electrical Tools and Products area at ElectriciansForums.net
Definitely find the mechanical clutch is better on the new one.
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Recommended Sponsor News
Hi everyone,
