project Peugeot 308 Rear Window Regulator. Worked out 4 connesctions | on ElectriciansForums
Discuss project Peugeot 308 Rear Window Regulator. Worked out 4 connesctions in the Auto Electrician Forum area at ElectriciansForums.net
Use to have this on my Renault when i disconnected / reconnected the battery.
Just needed to reset it using somthing like the following.
Fully open the window and continue to hold the switch for a further 5 seconds, then close the window and continue to hold the switch for a further 5 seconds.You might need to do this a few times before it resets the windows. This should reset the automatic window functions.
Reply to project Peugeot 308 Rear Window Regulator. Worked out 4 connesctions in the Auto Electrician Forum area at ElectriciansForums.net
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
