G
gerard
Hi,
I have a pizza press at work with heating elements going through the large metal platens that form the top and bottom press. The heating elements maintain the temp of the platens constant using on/off control. As a result of this the temp fluctuates quite a lot. So, if they are set for 160DegC, they can go +/- 8DegC. As a result of temp change we sometimes get sticking and ruining of product. Would proportional control tighten the tolerances and has anyone ever used PID control on inductive heating elements. Temp is monitored and controlled by Omron E5EK controller.
