G
Guest22
Ok, now before i get flamed this is proposed, i haven`t done this, i know its notifiable, etc etc. I am merely asking if this would be correct under the regulations which to my knowledge looking through them and into any de-rating factors, volt drop and any special consideration etc, And I can`t see anything that goes against them. Maybe that it could be considered bad practice is, the fact it spurs off from the spur but this is only to add RCD protection in the shed side of the circuit as to not let it trip in this house. Inside the shed it would be wired in 20mm PVC conduit or Flexible conduit, most information can be taken from the drawing i made. Note on the drawing, obviously the FCU within in the house isn`t existing. I wonder what you lot will say? Also, i understand i could put a garage CU on 4mm/6mm/10mm SWA with a new supply Coming from the exsisting CU, but i am not, and i`m not asking for other suggestions on how to feed the shed, merely if this is a within regulations to do so, thank you! Oh and
go easy, only an apprentice.
Its late so i bet this will have plenty of mistakes!
