proprietary earthing | on ElectriciansForums
Discuss proprietary earthing in the UK Electrical Forum area at ElectriciansForums.net
T
tanglewood
Hi
can somebody explain the difference between a proprietary earthing device and non proprietary earthing device , wit examples of each?:confused:
My interpretation would be designed for that purpose, or not. An earth clamp would be a proprietary device, a scaffold tube would be non proprietary.
Hi
Yes, I think you are the closest. my interpretation was a, proprietary device Is one specifically designed for its purpose. eg an Earth clamp. Non proprietary not specifically designed for earthing purposes. eg plumbers copper pipe. Thanks for all replies
Reply to proprietary earthing in the UK Electrical Forum area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
