Prospective Earth and Short Circuit Current, Earth Fault Impedence | on ElectriciansForums
Discuss Prospective Earth and Short Circuit Current, Earth Fault Impedence in the Australia area at ElectriciansForums.net
East London
Hi
I'm curent sudying for my 2330 and we have starting looking at the above, however I getting a little muddled/confused. Can someone please help me with some definitions and the us of the following, why we look at them?
  1. Prospevtive Short Circuit Current?
  2. Prospective Earth Fault Current?
  3. Earth Fault Loop
  4. Short Circuit Loop
Also what is the difference between an earth fault and a fault between line and earth?
Any help and clarity would be greatly appreciated!
Steve
  1. Prospevtive Short Circuit Current? fault current between line and neutral
  2. Prospective Earth Fault Current? fault current between line and eartrh
  3. Earth Fault Loop the fault current path, usually expressed as efli, the resistance of the earth fault path
  4. Short Circuit Loop assume the same for a L/N short circuit.
Also what is the difference between an earth fault and a fault between line and earth? ​none.
edit: an earth fault can also be a fault between N and E
Hi
Thanks, so I prosume that the impedence for both 3 and 4 should be low so that the high current flows to operate the protective devices in time?
Also, can you tell me what is the difference between an earth fault and a fault between line and earth?
Cheers
correct, the lower the impedance, the higher the current, and so the faster the overcurrent device will operate. and see my last post for the 2nd bit.
Tel has given some good info to help you as he always does, but if you need to get your head around it all then get hold of Guidance note 3. This explains and illustrates in detail everything you are asking, and its only a few quid. This book will pay for itself over and over again if you wish to progress in the industry.
Cheers...........Howard.
Reply to Prospective Earth and Short Circuit Current, Earth Fault Impedence in the Australia area at ElectriciansForums.net
How did it go?
