Prospective Earth Fault Current | on ElectriciansForums
Discuss Prospective Earth Fault Current in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sparky12021986
can anybody help me with this question?
Why is Prospective Earth Fault Current important during the design stage of an electrical installation..
For the same reason as prospective short circuit current is important...
Find out the actual figure by enquiry with the DNO or measure it at origin of the installation.
As a fault current in any installation will be the largest current ever expected that installation to be designed for, knowing that current will enable you to choose a protective device capable of safely breaking that current in the prescribed time .
Have a read of section 434 of the regs
Special thanks to malcolmsanford for such a straight answer thank you...
P.S. what Regs book are you reading..
that's the only one you should have. from jan 1st 2012, should be the green version.
Reply to Prospective Earth Fault Current in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
