prospective earth fault | on ElectriciansForums
Discuss prospective earth fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
davidjones89
if you were to work out the value of the prospective earth fault by calculation at point of the supply, what values would you need to do this calculation :confused:
The voltage and the Ze....
Simple ohms law V=IR so I=V/R, so the PEFC would be I, V is voltage and R is the external earth fault loop impedance.
Reply to prospective earth fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
