prospective fault current | on ElectriciansForums
Discuss prospective fault current in the UK Electrical Forum area at ElectriciansForums.net
J
Jake1579
i understand what pfc is - the maximum current that flows under fault conditions until protective device is operated.... and i know the difference between the 2 types
prospective earth fault current
prospective short circuit fault current
My question is what (path) would prospective short circuit fault current follow under fault conditions because i know with pefc its going to follow the earth fault loop path ZS so its going to have a low zs value so it trips quick. But what about if there was short on l and n i know if there was the breaker or what ever it would trip but i dont get how i know it will have a low resistance so it does trip quick but what path does it take if it is the earth fault loop path i imagine it will have a low zs but theres no earth involved if its on l and n is there??
Prospective short circuit current is the current which will flow through a short circuit of negligable impedance at the incoming supply terminals.
What exactly are you trying to ask here ?
say theres a short on live and neutral and you have that fault current flowing through it does that fault current on a short circuit between l and n just go into the protective device and detects that fault current and it just disconnects ??
The fault current will flow through every protective device upstream of it. One of these devices will clear the fault.
Hi dude,if you get out the generic fault path diagrams,which simplify the path from generation to fault,you can imagine,or draw your fault,L to N,and see the path of that fault current,and the protective devices it flows through.
There are some excellent drawings on some of the help threads regarding 2391,2394/5.
There is no shame in a picture,i have used these to learn,to teach,and to explain. Even drawing out suppositions i may have,regarding problems,can confirm things,when expensive components are going to be ordered.
...The Bayeau tapestry isn't on a memory stick......get yer pencil out! :icon12:
Reply to prospective fault current in the UK Electrical Forum area at ElectriciansForums.net
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
