E
eckersecker
I recently fitted a dual RCD MK board in a house. Everything has tested out fine but I was a bit concerned about the following readings. Ze is 0.03 ohms and the PFC is 7.3 KA. The supply transformer is just over the yard wall.
The breakers in the board are rated at the usual 6.0 KA. Do you have to change them?
