N
Nicktric
Hi, I have my assessment on the 23rd June and I've done my CU change which is mounted direct to brick garage wall however directly above is the garage roof which is joist and then a timber t&g deck above. The timber is about 50mm away from the DB. Do you think I should plaster board this? Fire board?
Cheers
Cheers
