K
Ken77
Hi,
Whilst it is not best practise, is there any harm in a 10mm G&Y cable running along the outside of a building. The cable is currently tied to existing conduit, (there is no space in the conduit to run additional cable) and is unlikely to encounter any impact in its location. So the only possible concern I can see if that of damage from the elements, however as the cable is on the shaded part of the house, direct sunlight is not an issue, which only leaves temperature. Installing additional conduit in which to house the cable is not doing to safeguard against this? As a guess range of temp is between -5C at to 35C.
Does action need to be taken?
