Protecting the feeder | on ElectriciansForums
Guest viewing is limited
Discuss Protecting the feeder in the UK Electrical Forum area at ElectriciansForums.net
Montana
This is a solar tie in generating 22 amps max current, hence the 25a/2p breaker on the subpanel but is there any reason the breaker feeding the subpanel has to be an 80a/2p? Can it be a 50a/2p?
  • [ElectriciansForums.net] Protecting the feeder
Reply to Protecting the feeder in the UK Electrical Forum area at ElectriciansForums.net
It all depends on the rating of the panel like 60 amp or 125 amp panels. You can never exceed the rating of the panel so having said that you can...
Here's how we generally protect circuits in the States, although GFCI breakers are also available.
