Protection Against Voltage Disturbances | on ElectriciansForums
Discuss Protection Against Voltage Disturbances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
John-
Uk
Quick Q.
Am doing 18th edition at the mo. Reviewing chapter 44 (from p95).
Calculated Risk levels for the the use of SPDs.
When you have calculated the risk level (CRL), what do you compare it against to know whether the risk is accelerate or not? Worked examples are in the regs book with results but they don't say what to compare the results against?
Also... Page 119 Table A444.2 two columns with the same titles (Minimum Separation between Power and Signal Cables (m)), both have different figures? Am i missing something there?
John
ok, feeling silly now. 1000 seems to be the benchmark - lower than needs SPD higher than 1000 does not. Sorry!
Reply to Protection Against Voltage Disturbances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
