Hi Guys
Ok so I have this little rewire on and have to put main protective bonding to services.
On the gas, it has been fitted in an external gas box in a shared part-covered passage D). I could bond in the box on customers side no problem. The pipe reduces down and is about 5m to point of entry of which 2m is outside. To bond on entry to the building is a problem as the boiler (fitted in the 90's) has the gas branching to boiler and cooker behind the boiler - so I cant get to before the branch.
Also interesting to note is the neighbour has 1.5mm T&E zipped to the pipe or their light. Cheek!
Thoughts?
TIA, David
Thoughts?
TIA, David
