Protective measures for fault protection on fused isolator | on ElectriciansForums
Discuss Protective measures for fault protection on fused isolator in the UK Electrical Forum area at ElectriciansForums.net
New Tredegar
Hi all new isolator through 200amp bus bar section controlled by 200amp isolator and fused at origin at 400ampincomer no breakers very old system needs panel thats the hard bit they wont spend money and they work 6 days 20 hours a day.
so what would you put in the box headed protective measures for fault protection on test sheet,and dont say ADS wrong?
Reply to Protective measures for fault protection on fused isolator in the UK Electrical Forum area at ElectriciansForums.net
