Protek CU | on ElectriciansForums
  • Thread starter Electricalserv
  • Start date
  • Replies 8
  • Views 1K
Discuss Protek CU in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
E
Electricalserv
Got a problem with a CU. Front cover won't screw on. Screws are not penetrating the holes as they have been excessively worn. How can I go about this without telling customer they need a new board because of 2 screws? Someone must have came across this>>>>
drill and plug with a couple of suitable screws..
Upvote 0
if the screw holes are not damaged apart from being worn. shove a cocktail stick down the screw hole then screw in the screws
Upvote 0
Reply to Protek CU in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
Hi All, Might be a stupid question but I have about 30 of these smart+guard alarmed call point covers to deal with. All the batteries are dead...
Electrical Courses
