Proteus Fuse Holder replacement to RCBO | on ElectriciansForums
Discuss Proteus Fuse Holder replacement to RCBO in the UK Electrical Forum area at ElectriciansForums.net
Goole
Hi,
I will not be carrying out this work!! a qualified electrician will be.
however
Could someone let me know if it is possible to change the Proteus Fuse holder's to RCBO'S please?
[ElectriciansForums.net] Proteus Fuse Holder replacement to RCBO
I've been advised on using a FUSEBOX CU, However should I go for a 7 or 10 way.
Cooker
Outside office
Sockets up
Sockets down
Lights up
Lights down
the biggest that fits in the space (with a little wriggle room!)
Reply to Proteus Fuse Holder replacement to RCBO in the UK Electrical Forum area at ElectriciansForums.net
well then, must be a fault on the circuit, a faulty appliance if a power circuit or a faulty RCBO.
If they are standard RCBOs the MCB aspect could be b,c, or d , but the RCD aspect is almost certainly 30mA instantaneous. If the MCB aspect...
