Provision and Use of Work Equipment Regulations 1998 | on ElectriciansForums
Discuss Provision and Use of Work Equipment Regulations 1998 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It is the first document in Archy's post that you may find more useful:
Source link here:
http://www.hse.gov.uk/pubns/priced/l22.pdf
This is what HSE will judge you against in the event of a case as it is an "Approved" code of practice which as I have said in other posts is a Quasi-Legal document.
This is what I always guide my clients to when I am doing design, electrical consultancy or H&S consultancy with them, as IF you can prove that you have done what is in here or better then you will have almost certainly have done all that could be considered "reasonably practicable".
The head of HSE electrical in my area, along with one of his control specialists, agreed when we discussed this at an IET meeting also.
Reply to Provision and Use of Work Equipment Regulations 1998 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Mine is a Telequipment D75 from the 1970s. Still working spot on. Proper dual beam as well and very high EHT for really bright traces.
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
