PRV with Gauge Question plumbing advice | on ElectriciansForums
Discuss PRV with Gauge Question plumbing advice in the Plumbers Forums area at ElectriciansForums.net
PRV with Gauge Question Hi,
I have a Caffeli PRV near the mains stopcock. Static pressure fluctuates between 3-4 Bar and when a tap is opened it sits around 2 Bar. No issues with pressure but trying to gain an understanding of how it should be setup to protect appliances. I do have a couple of Grohe toilets that make a slight thump when the filler shuts off abruptly.
With taps running is I adjust the PRV I can decrease / increase the pressure but it tails off (doesn't increase) beyond 2 Bar. Is that where I should set it at? From what I have read, the fact that my PRV adjusts pressure with water flowing indicates that I can't control the static pressure. Is static pressure of 3-4 Bar too high?
Thanks in advance...
PRV with Gauge Question to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to PRV with Gauge Question plumbing advice in the Plumbers Forums area at ElectriciansForums.net
M
Low pressure light coming on. My Ariston Eurocombi A23 low pressure light has started to come on. When the kitchen HW tap is on the boiler...
Merton69
M
This is an RSS feed of thread: Damped oil pump pressure gauge recommendation Content of the thread: I have 2 oil pump pressure gauges, a Nu-Way...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
