H
hondairder
Hi all
New here and in need of some info.
My situation is as follows : I have a 306 with a faulty door loom. When i first experienced the problems i googled it and got a lot of suggestions to peel back the rubber on the door loom and see what it revealed. I did this and it revealed a plug with 14 wires in most of which were broke are breaking. I stripped the door panels off which had the socket for the plug with 14 wires going to that. The problem of the door looms failing seems quite frequent.
My plan is to bypass the plug and and using sutiable connecters, connect the 14 wires from the plug to the 14 wires from the socket.
The problem I am having is what wire to use. The plug contains 14 wires, 1 fine wire, 2 thicker wires and 11 medium wires.
The socket has 3 thick wires and 11 medium wires.
Im not an electricain (evidently) but my question is what wire do i use to join the plug wires and socket wires together.
My logic says if i was joining 2 lets say thick wires with a thin one, the thin one could melt / breakdown.
What I am contemplating is, so long as the wire I am using to join the 2 cables is thicker than either cable being joined I will be fine. When I say thicker I am referring to the copper diameter not the out sheath diameter.
I have already worked out which cable relates to which pin on both plug and socket so I know which 14 sets of 2 cables need joining. My problem is cable choice.
Your advise / help would be much appreciated.
Simon
Simon
