pull cord | on ElectriciansForums
Discuss pull cord in the Australia area at ElectriciansForums.net
I thought local isolation was a must with any fixed appliance?
That's a myth. Nowhere in the regs does the words 'Local isolation' appear.
If not its good practice!!
It may be considered good practice in most cases, but that's not what the OP asked. In response to what he did ask, no, we don't need to put an isolator in unless the shower contains an integral pump (motor). And even then, in some cases, you won't need to either.
Reply to pull cord in the Australia area at ElectriciansForums.net
as mentioned by Westward a link is the way forward, nothing wrong with that and the pull cord will then be the on off switch.
Mira showers with the computerised PCB in them go wrong all the while, we connected up 30 odd new showers in a retirement complex for a plumbing...
