pull switch | on ElectriciansForums
Discuss pull switch in the UK Electrical Forum area at ElectriciansForums.net
M
martinsayer81
hi guys,
just a quick one, what zones can you fit a pull switch in a bathroom?
i have to fit a shower-light-fan combo above a bath that has a shower in it, can i fit the pull switch in the ceiling above the bath at the opposite end to the shower? This way it makes it obvious that the pull switch in the bath is for the fan,
and one other thing, what do they mean by an 'insulated' pull cord? do they mean a plastic pull cord?
cheers guys
plus the bathroom is quite small and the pullcord would look silly in the middle of the ceiling, plus there is already a pullcord just as you come into the bathroom for the other ceiling lights..
ceiling height is 2.4M from floor level,so its outside the zones but when standing in the bath i can touch the ceiling!
If it's at 2.4M then it is outside zones. Simple. If it is a piece of string, as is the norm, then it is insulated as far as the regs are concerned.
If you personally think that it could be sprayed then you can make the decision to move it further away.
wouldnt it look a bit cluttered with 2 pullcords side by side, and i think it would get confusing to guests as to with cord is for the lights, i want it to look good and be safe at the same time.
I always like to get the customer involved. Work out yourself where you think the pullcord is safe, then give the customer a few options. They will choose exactly where they think it looks best out of your suggestions and everyone is happy. Nothing worse than doing something you think is right, only to have an unhappy customer say "Oh, I don't want it there".
Why not loop it off the existing lights?
One thing to bear in mind is just because it is outside of zones doesn't necessarily mean that it will be suitable for the location, as the installer you make the decision if it is fit for the external influences.
thought it might be a nuisance if the fan kicked in when someone just wanted to use the loo late at night, when others are asleep!
Reply to pull switch in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
Better off with the click prw213 as it has twin screw termination.
