pulling SWA through conduit. | on ElectriciansForums
Discuss pulling SWA through conduit. in the Talk Electrician area at ElectriciansForums.net
1Justin
Surrey
32mm plastic conduit. Intention is to run it 6M under concrete floor and use bend spring on ends to bring it vertical. Conduit will be cut off flush with FFL.
Concerned about the bends, do you think I'll pull through a 6mm SWA after the event or would you install it before laying the floor?
Use the proper ducting and you can buy the preformed bends , that should make the job a lot easier. Slightest kink and you know whats next lol.
I was guessing I'd get more gentle (ie easier) bends with the spring. I'd sooner go preformed. Would 6mm SWA go round 2 of those do you think?
Can't see you having much of a problem pulling either a 2 or 3 core SWA cable through a 32m duct. Personally, if there is any chance of damage to this SWA cable if pulled in prior to use, i'd rather pull in a suitable draw line and install the cable later.
Manufactured slow 90 deg bends are fine, you may have a problem with manufacturing them yourself, i'd heat the area of PVC duct first before trying to form them with the spring if you do go down that route.
Another detail to watch,is which side of the DPC you will be,and how you breach it,if you have to.
Worth a thought,if cast over insulation or is set for wet UFH.....or just a eagle-eyed BC inspector :icon12:
I assume you have checked your bending radii will comply on the swa when using pre-set manufactured bend...?
I was only assuming "sweep.radius" bends anyhow (or DIY). The clipsal/Schneider one is > 300mm on the 32mm (wow) and 150 on the 25mm. Good point though.
Not if the cable cable is just going to lay on the floor waiting to get damaged by the builder or whoever. Id say that it's defo not the way to do it!!
I would agree with you with builders in the area , but I would ensure some protection is in place for the cable and advise them about care to be taken , if the guys are that bad then maybe they would dislodge any joints on the conduit , so Pulling the cable in and protecting it is what i would do ..
Reply to pulling SWA through conduit. in the Talk Electrician area at ElectriciansForums.net
Sounds more positive.
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
