Pulling the fuse on top-up meters????? | on ElectriciansForums
Discuss Pulling the fuse on top-up meters????? in the Talk Electrician area at ElectriciansForums.net
R
rocker
For my billionth question today, does anyone know what happens if you pull the fuse on a top-up style electricity meter (you know, the one with the card or fob and you buy credits from paypoint or whatever), would the customer lose all their credits?
if that were the case, they would lose their credit in the event of a power cut, and i've never heard of that.
But what happens when you put the fuse back in?
The meter lights up and....that's about all. Had me baffled the first time I encountered one of those!
There's a time delay before the contactor is energised. Not sure if it's a random value programmed into the meter, or it is signalled in some way.
Suppose it's to do with minimising the inrush on the distribution equipment when re-energising after a power cut.
Simon.
Reply to Pulling the fuse on top-up meters????? in the Talk Electrician area at ElectriciansForums.net
Happens on every job of ours, houses are usually empty for a year or so and they are always £300-£400 in debt mostly due to the standing charge...
I agree, it is a bit unfair when they change the rules. however, as a nation out usage patterns are changing and the most cost effective tariffs...
