Pump cable gland. | on ElectriciansForums
Discuss Pump cable gland. in the Electrician Talk | All Countries area at ElectriciansForums.net
Sparkattack
Does anyone know of gland to use for flat 4 core pump cable. The cable is 16mm2 4 core and its about 1"1/2 in width x 3/4" thick(similar to pic below). The application is for 2 inline pumps located in a chamber and each pump is wired into a JB. The current setup is SWA feeding in IP65 JB's and the pumps have been brought into box through a brass stuffing gland with a shroud taped up around it. Inspection of JB's i noticed water ingress, could do with a better termination into boxes which im planning to replace and relocate to a better position.
cheers.
Martyn
[ElectriciansForums.net] Pump cable gland.
I've just finished jointing a cable like that! We couldn't get glands fir the blue flat quick enough, so I've resin jointed it onto a round cable, and put that through a brass stuffer.
Reply to Pump cable gland. in the Electrician Talk | All Countries area at ElectriciansForums.net
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
