Pump question | on ElectriciansForums
Discuss Pump question in the Central Heating Systems area at ElectriciansForums.net
the pict
Mentor
Brodick
Should the CH pump run constantly, my own one does, but a customer asked the question, its a oil fired combi, I wired the controls and the plumber signed it of as ok perhaps the client is just a wee bit anxious
Pict
Pict
No it shouldn't. It should go on and off when the boiler kicks in and out or if the boiler has an overrun function to dissipate the heat within the boiler then the pump would stay on until the boilers internal pump overrun thermostat turns the pump off.
Thanks all, It is as Lee says, I was wrong about my own it stops but the boiler fires up till it reaches a preset temp and maintains that when OFF,
Pict
Reply to Pump question in the Central Heating Systems area at ElectriciansForums.net
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
P
Worcester Bosch Greenstar Regular Boiler - Always ON Morning all, I've noticed very recently that our Worcester Bosch Boiler is constantly ON and...
Pgeddon
P
The pump is controlled by the boiler on an 18Ri.
There's an arrow cast into the pump body which shows direction of flow. It's also fairly obvious from the back of the pump - you can see by the...
