pump running continuously | on ElectriciansForums
Discuss pump running continuously in the Central Heating Systems area at ElectriciansForums.net
anyone any dealings with British Gas wireless receiver WR1 ?
pump on heating system seems to be running constantly ,boiler seems to switch off but come back on very quickly two zone valves seem to be operating as normal.
pump is running even with programmer switched to off position,I'm just wondering if the receiver is faulty (never encountered one before)
thinking of disconnecting recieiver
yes I pulled up the manual off the internet,so there should be a 4 core running from the boiler to the wiring ?
I'm working from photos taken by son who is 160 miles away....
The pump is more than likely connected to the terminal marked pump feed. With a voltage indicator it could be checked to see if it turns off or not, when it should.
by the sound of it it appears the pump does not switch off, as he has held his hand on the casing of the pump and it feels like its runnimg all the time, I dont want him taking covers off of anything so cant tell what the connections are
He needs to get someone competent in then and not someone whoโ€™s going to play parts darts.
quick update on this,travelled down to visit son and check the wiring out.1st picture is the "wiring centre" 2nd picture wiring centre with cover removed.Ive traced all the cables back and they are all connected as per the s plan for the potterton boiler,the boiler has 4 terminals with the unused terminal being the pf, thats the extent of my knowledge done so as some one mentioned previously its possibly an internal boiler fault (pcb ?) so Im afraid the parts darts master is going to get another go at it....
[ElectriciansForums.net] pump running continuously
Reply to pump running continuously in the Central Heating Systems area at ElectriciansForums.net
W-plan pump run on Son recently moved into a 20 year old house with what appears to be a W-plan system using, I think a Worcester Bosch Greenstar...
davidwf
B
Replace central heating gate valve with 2-port valve My house has a separate central heating loop that heats an annex. The annex loop has 3 x...
Barnjet
B
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy ยฎ
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
  • [[Official~Expert]] Contact QuickBooks Desktop Support Customer Service HElp QB Support
    To contact QuickBooks Desktop Support via phone, dial โœ…๐Ÿ“ž +1-844-881-9274 +1-844-881-9274 or #...
