Pumping over plumbing advice | on ElectriciansForums
Discuss Pumping over plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Pumping over Hi everyone we have an issue with the f@e tank it’s an open vent system gravity fed and the pump is pumping over into the f@e we had the the pipe work for the cold feed changed as it was clogged however it is still doing it even with the pump turned down it’s looking like the vent has been placed on the positive side of the the pump. Can the vent pipe be placed on the return or can we move the tee joint where the water goes up into the loft for the vent and place it elsewhere ? The tee connects into the cylinder then goes straight up.
Pumping over to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Pumping over plumbing advice in the Plumbers Forums area at ElectriciansForums.net
A
F&e tank vent pipe pouring hot water Hi all I have an oil fired heating system open vent with an f&e tank we had some problems with air...
Andymav
A
P
Baxi 105e pump head removal Hope you confirm something’s for me, boiler calls for how and ch but am not sure if pump is rotating, have checked if...
Plipplop
P
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
