Pushfit fitting/pipe ok to rub against one another? Hi
I've been swapping rads in my house and during one rad swap I used the original notches on the joist to run the new flow and return pipes. In one notch both the flow and return touch and might get pressed against each other when the chipboard goes back down.
Should I open up the notch or reroute the return (left valve pipe)? Or is it ok they touch together?
I've attached photos to illustrate, last photo is a general picture of the whole setup
Thanks in advance
Pushfit fitting/pipe ok to rub against one another? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thanks in advance
