T
tombrooker84
Hello Guys,
I've got a garden lighting job to do, there is an exisiting supply, fed from a flexible conduit (not great, but without ripping up a patio it will have to do). Currently it is fed from from a MK sentry 16th edition split board, without RCD protection, so I was going to upgrade the circuit by replacing the MCB with an RCBO, however this obviously means I take responsiblity for the entire circuit, and there are literally 20 X MR16 12V fitting on the circuit, all fed from dimmer switches and the house is beautifully decorated. How would you go about testing them? I mean doing an IR test will be nigh impossible unless at 250v? And R1 + R2 just at the switches and not the fittings?
Cheers
Tom
Cheers
Tom
