Putting light fixture with 2 bulbs on a single bulb ceiling outlet | on ElectriciansForums
Discuss Putting light fixture with 2 bulbs on a single bulb ceiling outlet in the Lighting Forum area at ElectriciansForums.net
farmerfa
Sydney
Hi all. We have a light fixture that has single bulb fixture on ceiling.
I want to change this to a 2 bulb fixture. Is this just as simple as removing the existing fixture and wiring the 3 into the double bulb one?
I see black/red/greenyellow wires currently attached.
Not so good with electrical things and still want to do DIY for simple things like this. Please help. Thank you.
Take a picture before you remove any wiring. Make sure you do safe isolation.
Would be better if you got someone in though, it'd be 50 quid and 10 minutes of their time to do it properly.
And yes, amount of bulbs doesn't matter.
More like 85 Aussie dollars for the OP
Reply to Putting light fixture with 2 bulbs on a single bulb ceiling outlet in the Lighting Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
