Putting UK plugs on hard wired appliances | on ElectriciansForums
Discuss Putting UK plugs on hard wired appliances in the Electrical Appliances Forum area at ElectriciansForums.net
philch1
London, UK
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer (AEG) as hard wired. I recently purchased a new hard wired microwave, but the installer discovered that there was only a socket behind the microwave. He cut the plug from the old microwave and attached it to the new one. He checked the oven for me, and discovered that also had a plug. I was planning to replace the oven next.
Should I consider getting an electrician to replace the current plug sockets with hard wired points instead? If so, how much should I expect to pay?
Most appliances come with a plug fitted if they are rated 13amp.or under. If not I would just fit a plug top. If it's rated greater than 3kw then it's a different matter all together.
Changing a socket to an outlet would only take a sparky 15 mins including testing it I would think. Assuming of course access is easy and he is not having to move your kitchen appliances 😂
Reply to Putting UK plugs on hard wired appliances in the Electrical Appliances Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
First thing to say is that it's desirable to have a method of isolation for the oven somewhere near it in the kitchen, and not hidden behind a...
