SparkPlug
We intend installing approximately 1x20KW or 2x10KW PV panels to a 2 phase and neutral system in a building. To balance the phases, do we connect 10KW to each phase as the both phases go through 1 meter.
Also, what would be the position regarding the connections to a TP&N supply?
Thanks in advance.
Are you sure it is 2 seperate phases and not a split phase system???
Is the building an agricultural???
No, not an agricultural building. It's a large retail/electrical outlet.
The supply from the transformer entering the building has 2 live conductors terminated in the supply authority meter and the neutral bypasses to the distribution board and I assume that's a 2 phase system but I may be wrong.
PV connection to multi phase supply
SparkPlug,
SparkPlug,
