PV DB wiring | on ElectriciansForums
Discuss PV DB wiring in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
[ElectriciansForums.net] PV DB wiring
Anyone used this method of wiring, incoming supply feeds mcb first then rcd and out from the top to the meter.
Rcd tested fine but never come across this before.
Worst thing was that the incoming supply went straight through the ac isolator which is just to the left and into db
Cheers
Nice to see bare wires going into the MCB......
It's an interesting interpretation of installing the RCD at the Inverter end...
Normal practice in Cyprus, however main to RCD 1st then to 2P MCB onto the inverter, ac isolator not required but no problem.
Reply to PV DB wiring in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
