This is the controller you need :-
www.sgwooldridge.co.uk/solarpvswitch
Its unique in that it actually senses the net power available for export and diverts it, however small, to the heater, normally a hot water heater.
No need to fit a smaller immersion heater it uses the standard 3Kwatt one ,and never imports power for the heater. It just patienly waits for net surplus of pv generated over consumed power.
Will even power additional loads like towel rail heaters etc if purely resistive.
Operates even at 50 watts surplus power! These are great devices and should save its cost in less than a year.
I have three running on my properties heating background heaters, hot water, towel rails.
The secret to paying back quickly is to ensure that
all surplus power is used, even when the water is up to temperature.
You can do this by parrallelling loads, as the maximum output power will not exceeed your peak Solar PV power.
It will even work with a 3Kwatt oil filled electric heater in parrallel with the immersion heater.
You must make sure though you do not import power which this controller won't, but other simpler switches do.
A simple calculation based on say 4Kwatt Solar PV generating 3500kwatt hours per year at say 11p per kwHr could save ÂŁ385 if you used all the surplus power.
Also factor in you can switch of the central heating from around now, due to the back ground heating, which otherwise I would have kept on just to do the hot water.
Has anyone got any experiences with all these new products that are coming out to direct excess generated electricity from a PV system to your immersion? I'm getting a few of my customers asking about them. The ones I've found seem to just use a relay switch once there is a certain amount available (usual a minimum of at least 1kW). I would have thought there would be a more efficient method. They also seem quite expensive for what they actually are.
Any thoughts would be much appreciated. Seems hard to sell something that might only save the customer maybe ÂŁ30-40 a year.
