View the thread, titled "PV meter not going up??" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
M
mikeeb12000
Hi
I've recently got involved in PV installs and after my last 2 the generation meter is not going up or any movement at all.
Any ideas guys.
cheers
As long as you have generation from the PV array you need to reverse the connections inside your kwh meter.
From left to right - from PV array - L N N L - to mains CCU
Hope this helps.
Yes, you have to connect them backwards, to what you would normally. Like the last post says, your array is the mains in and the cable to the CU is the load.
Reply to the thread, titled "PV meter not going up??" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
