Now I've also begun to use a serial lead from my Kaco invertor to log output on Kaco's logging program on my PC. This is compatible with pvoutput.org's excellent logging program which enables me to view output almost live (with updates at 10 minute intervals) on the web and compare with neighbouring installations. This is highly addictive but is only good if you already have a server running continuously to do the logging, which appreciate rules out most households - I run a web server 24/7. I guess some invertors might output to the web directly, but mine needs a pc to be connected.
Hi Greenslade. I'm interested to see you're using the
Kaco logging software with a serial lead. I'm trying to do the same, but having trouble making it work. I wonder if you could help me?
I have a
Kaco Powador inverter connected via serial-USB converter to an old laptop that I no longer use so have been able to put up in the loft and have downloaded the
Kaco-Viso software for it (version 2.2.1.0, which seems to be the latest on the Kaco website). I've not yet decided whether I want to leave it there permanently, but I'd definitely like to be able to leave it running for a week or so if I go on holiday, so I don't get any gaps in my graph even if I'm not there to read the inverter and/or generation meter.
I found it a bit fiddly to get it to log anything, but eventually got it started yesterday, and it logged fine until sunset. However, this morning it didn't start logging again when the sun came up and the inverter switched on. I've checked on it this evening, and the
Kaco-Viso software was still running, but the row of numbers along the bottom still had yesterday's date on it, so it didn't seem to have received anything today at all.
Have you (or anyone else) any idea why it might do this, and what I could do to make it work properly?
