K
kippaxkid
Hiya,
I know rockall about PV, and they are due to put one on our building soon. This has been given to outside sources so we have had no input, and even if I had been asked I'm not sure what I could have contributed. But it still scares me, as the company involved have been used to installing on domestics, and are now stepping up to a 50Kw on a metal barnd style building with metal doors. You get the picture.
All the existing bondingand earthing is bob on, but I cannot see that as an antidote to the squeaky bum. That will just disconnect the main supply. It won't block out the sun.
If the cabling from the PV array is allowed to enter a building through a metal clad wall, and if the only isolation point is above the inverter,( some 10 metres from the input point, which bit trips in fault condition? Surely it should have a seperate fused isolator at the mains input position?
or does the panel shut down if it detects a short, and if so, how long after seeing it does it shut down?
Curiously yours
Chris :thinking:
Curiously yours
Chris :thinking:
