pv panels upside down? | on ElectriciansForums
Discuss pv panels upside down? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
saggers
If running 2 rows of panels it is wise to have the connectors at the bottom on the bottom row in case they need to be unplugged in the future?
If in doubt, best to have junction box at the top if possible. One manufacturer says:
"The correct order to orient the module is vertical with the junction box on the higher side of it. The reason for this is that the breather port in the junction box, must be mounted facing downwards and not be exposed to any rain."
Reply to pv panels upside down? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
as @SparkyChick says, it is not difficult to make an enclosure that is sealed to IP66 standard from above and have holes in the bottom. (IP66 is...
Thank you so much for your help with this light work perfect now thank you again much appreciated
