SimpleSimon
Got a retractable pool cover, run by two motors either side slide back.
Motors are fed by a PV panel. Very simple set up. However I am limited to these installs.
Would it be a good educated guess to say because neither motors are working there would be a fault with the PV panel?
Both motors and batteries inside casing look fine on inspection and testing there was no voltage to the battery on either side.
I just want to make double check before I order a new panel invade there is something I've missed.
