PV*SOL & Sunny Design Yield? | on ElectriciansForums
Discuss PV*SOL & Sunny Design Yield? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
W
willabovebeyond
Hi
Would anyone be able to quickly run this through PVSol for me please?
Panel: Sharp NU-R250(J5)
Quantity: 8
Azimuth: 45 deg
Roof pitch: 40 deg
Inverter: Sunny Boy 2000 HF-30
Unshaded
I'm looking at the difference in estimated annual yield between Sanyo HIT 250 and Sharp NU-R250(J5).
Sunny Design doesn't have the Sharp panel listed and I fear that the data I have input to add the panel to the system may be incorrect/inaccurate.
SAP just gives the same reading for both panels as they are the same power.
If anyone could help me out that would be great.
Thanks in advance!
Will
Hi Will,
If I run both systems through PV Sol I get the following results (based on Solihull as location):
Sharp 250s - 1,499kWh
Sanyo 250s - 1,643kWh
The only thing going for Sharp panels is brand recognition.
Reply to PV*SOL & Sunny Design Yield? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
