Hi Infinity,
You are correct in assuming that the
TMPV4 Kit has everything, also regardless if you are working with MC4 or MC3 connectors. The TMPV4 kit basically allows:
Measurement of solar irradiance (using
Tenmars TM206)
Measurement of Isc and Voc (using
MD9230 Clamp Meter)
Remote panel temperature measurement (using
TMPV:IR50 IR Thermometer)
Angle of the panel (using the small
Digital Protractor)
Crimping MC4 connectors (using
MC4 Crimping Tool)
Tightening MC4 Connectors (using
MC4 spanners)
Crimping MC3 connectors (changing the dies in the MC4 Crimping tool to
MC3 crimp dies)
Assemling MC3 connectors (using the
MC3 Assembly Tool)
Connect the Clamp Meter to the PV installation (using
MC4 Test Lead Set)
Label the installation with
Solar Warning Labels.
All 4 kits come supplied in a customised robust carry case and all the test equipment (excluding the Digital Protractor) come supplied with a Certificate of conformity (the IR Thermometer comes with Cal. Cert.)
If you won't be coming across MC3 connectors or do not need the IR thermometer and Digital Protractor, then it may be an idea to look at the
TMPV3 kit.
All the kits are in stock and we appreciate that due to the current situation, the equipment in most cases is needed urgently. We are trying our best to send everything out same day, but due to high demand it cannot be guarateed. If you have a deadline or specific date that this is needed for, give us a call or a PM and we will try and sort it out.
