PVC channel | on ElectriciansForums
Discuss PVC channel in the Electrical Tools and Products area at ElectriciansForums.net
P
peteelecs
Hi
could you please tell me what type and length of nails I should use to nail pvc channel or capping to brickwork
hi peteelecs
i use clout nails 60-70mm long as they have a nice big head to go over the edge of the capping.
be warned though, in some older properties the mortar just disintigrates or the builder used almost pure cement in the mix and you can't hammer the nails in!! in these cases i have been known to drill the brick and insert rawl plugs and screws. hope thats helpfull.
on a good block wall 1mm or 2.5mm clips are good and are a help to plaster holding on to a smooth pvc channel.plus youve always got some to hand....
Reply to PVC channel in the Electrical Tools and Products area at ElectriciansForums.net
Shower screen reinsert problem Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens...
Sandy283
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
