PVC conduit and glue | on ElectriciansForums
Discuss PVC conduit and glue in the Australia area at ElectriciansForums.net
Not sure of Australian regs, but I would think if it’s outside, it would need to be glued to prevent ingress of water….
But then, in the UK, we do get much more “outside water” ie, rain, than you do down under.
Bear in mind it will have less movement available if all the joints are glued, and so may warp more in high temperatures.
Reply to PVC conduit and glue in the Australia area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
