PVC conduit cutters | on ElectriciansForums
Discuss PVC conduit cutters in the Electrical Tools and Products area at ElectriciansForums.net
i use some with a trigger, similar to mastic gun, squeeze and blade advances . similar price from elec. center.
I've got a pair of Draper Expert ratchet ones which give a nice clean cut but they take up quite a lot of space in my toolbox, so started using the cheap ones from Screwfix, which seem to work fine.
I would steer clear of the big 'scissor action' ratchet ones which do mini trunking as well, because they take both hands to open and squash the tube as the blade gets blunt.
i use these... :)
[ElectriciansForums.net] PVC conduit cutters
:eek:Ah! post after my own heart
bought several pairs of cheap nasty scissor type ratchet ones from (CPC) and ..wasted my money. ended up throwing them away.
If you want to doa professional job you need the tools and ÂŁ20 is not much to ask so bought a CK pair with lots of attachments and man they are superb.
Like a hot knife through butter. I have been using a hacksaw for years and I realise now how 5h!t that is. (Lenny I think you were jesting with your suggetsion:eek:
please excsue spelling beered up
Reply to PVC conduit cutters in the Electrical Tools and Products area at ElectriciansForums.net
Best tile cutter Hay there, Need a new tile cutter 600 minimum, I’ve used one from topps tiles which was ok, but I need to upgrade that’s why...
Plasplugs wet tile cutter - it sucked! I recently borrowed a plasplugs wet tile cutter from a friend to cut some floor tiles. In his opinion this...
STEVEROG
