PVC conduit cutters....... | on ElectriciansForums
Discuss PVC conduit cutters....... in the Electrical Tools and Products area at ElectriciansForums.net
G
Guest55
anyone use them ? what they like ?
sick of rough cuts from hacksaw even with new blade so thinking
of pulling the trigger on a CK set for 20 notes.
I bought a set of pipe cutters when I was doing some plumbing,yes the dearer one are great but on the cheaper ones the ratchet slips when you use them on a harder plastic.If you know anyone who works for brewery tech services a set of PYTHON cutters do the job brilliantly.
[ElectriciansForums.net] PVC conduit cutters.......
ÂŁ20 free delivery from amazon, been using for a while on pvc trunking and conduit
Got given a free set my a plumber once when wiring a boiler house at a school. Look as cheap as anything and has served me well for the last 5 years.
Reply to PVC conduit cutters....... in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
